I hooked it up like the beautiful drawing above with a 10 amp fuse in between. The first time after switching the power on, the fuel sensor (out of the tank) starts to smoke and the light comes on, light on is good, smoking not so much. But then after I switch the power off and on again the light never comes on anymore, probably because it burned. I connect the + wire to a switched line and the light is in between ground and the sensor.
This is the sensor:
What am I doing wrong that the sensor just starts smoking and doesn't work after anymore?
