Okay so I parked my bike Wednesday (it's Monday today so 5 days) and accidentally left the ignition in "p" so my battery went dead. No problem I jumped it with my truck. Now normally it starts after one or two turn overs and it's fine. This time it started and ran for about 2 or 3 seconds then died. It did this a couple times until I started it and then revved it up a bit then it started idling just fine at about 1k like normal. So I let it idle about 5 minutes and then hopped on and took off. I gave it about a quarter throttle and it just kinda went "glub glub glub" and died. It felt as though it was flooded, no power at all and no response. Now I did leave the gas on, but I've never had a street bike flood on me before from leaving the gas on, just dirt bikes.
Anyhow, instead of fiddling with it I thought I'd ask what might be the problem as this seems pretty out of the blue to me. If I was forced to guess for myself I'd say it's flooded because it was running great before, but I'm not a mechanic. And I don't know the best way to unflood it if it is just flooded anyway.
Either way, thanks guys
1992 fzr600 won't run
- et_miller_87
Re: 1992 fzr600 won't run
Id say it's probably because your battery was still super drained. It only charges above 3k and with a drained battery, it doesn't have the juice to keep those coils powered like it should. I'd suggest charging your battery and then trying a short ride. Even though it's not necessary, a load test wouldn't hurt either.
Okay. I didn't even think of that. As far as bikes go I'm used to simple little 2 strokes.
Okay I will hook it up to my charger and then see what happens with it.
- et_miller_87
Any news?
