On light to medium braking i feel some vibration through the handlebars. I can also look down to the forks and watch them shimmy around at the wheel during braking.
Things i've done so far-
Steering stem baring is new, not too tight, able to swing the front around freely.
Forks have progressive springs, double checked fluid level today and they're right on 4inches fully depressed. 10w oil
Checked torque on front axel, stem nut, fork pinch bolts and brake disc bolts.
r6 front brake setup (master cylinder, lines, calipers) New pads.
I think its the discs, but I want to make sure theres not something i'm missing before dropping that $$$
I never did a fork alignment either, could that be something?
Thanks for looing
