Bike ran good before, kinda had a hiccup at 3grand and a weird idle, had been telling myself to reshim valves so I finally talked myself into it
Tried adjusting valve clearances, exhaust side was tight, intake was fine, reshimmed now all are within spec
Upon re-assembling realized my battery was never disconnected, battery was shit anyways, assumed all is well
Tried to fire for first time, engine sounded better cranking but never started
Start tracing around for a forgotten connector possibly that wasn't hooked up, no luck
Check fuses, blah blah everything appears to be fine, also purchased and installed new battery at this time
Still no start
Go through Don's "Now What" thread, everything test out fine (stator, coils, safety circuit, everything in the thread,) but no spark to be found
Eventually upon a suggestion of using the header bolt as a ground rather than the head, I was able to see a little glimmer of spark
Hooked all back up to fire it up, still no luck
So a few weeks pass and I want to ride worse than ever
Pull valve cover back off to verify shim accuracy and timing, all within spec and timing seems to be lined up by split in casing to the lobes and dimples on cams
Check on the bike, no spark still, check safety circuit for continuity, checked ok but has high resistance attributed to kickstand switch, so I bypassed it now has lower resistance (50+ ohms down to 2-3)
Now going through Dons "Now What" thread again, I checked the secondary resistance on the coils as 36k ohms now, primary as 2.5ish ohms, both out of spec, secondary by 3x spec (12k ohms)
I had always thought i may have messed up something since I stupidly forgot to disconnect the battery, could I have fried the TCI? If the TCI is fried would it have taken out my coils as well?? I want to rip it apart the TCI to get a visual if any burnt traces, or drives or whatever magic stuff contained within looks burnt. Anyone know how to rip into these, or have suggestions as to how I can get back on two wheels without having to steal my daughters bicycle?? Its pink but i will do it dammit.
