Electrical help
Electrical help
I got a 1998 fzr 600 just bought, will only ride for about 1 hour and the battery dies, its a brand new battery, i just bought a new regulator rectifer, but still just dies slowly, before i pay for new stator do any of you guys think that it could be wiring, the wire that goes from battery to regulator has a 40 amp fuze between it, when i put the test on battery i loose about 0.01 every few seconds and when i rev the bike it just goes down like 0.04v and goes back up just wondering the wires are really beat up from the stator and to stator..
Thanks for looking
Thanks for looking
- et_miller_87
Re: Electrical help
What is your voltage before start, after start on idle and revved above 3000?
Re: Electrical help
I can find out tonight, but when battery is full its between 12-13v and then when i start it and idle it sat at the samr, also when i reved it the voltage stayed same besides loosing like .04 volts when reved and then goes back up liie .03 volts
Re: Electrical help
Do your checks as et_miller suggested, but then unplug the VRR and measure the AC voltage across the 3 white wires. Check the AC voltages in pairs; 1-2, 1-3, 2-3.
Re: Electrical help
New aftermarket or OEM rectifier ? I would go with OEM. I have heard Rick's makes good products.
Re: Electrical help
Its just a OEM i got off evay for 17 bucks.. before i buy a nice one i just wanna see if thats it
Sent from my SM-G920P using Tapatalk
Re: Electrical help
Afternarket i mean
Re: Electrical help
So its 13.6 off key turned 12.8 v idling 12.48.... and when reved its just drops about 0.01 every few seconds
Re: Electrical help
Re: Electrical help
Re: Electrical help
Re: Electrical help
The one connector looks melted and corroded, do you think the stator would do that if its bad? Or a short.. either way i ordered a new stator not sure where to find a new connecter either for the other side once i get the new stator
