List your carb setup
Posted: Fri Aug 22, 2008 9:22 pm
by davephipps
I've seen quite a few posts on this forum asking for Carb help. I was thinking that it might be useful to list our working carb setups.
I'll start. Mines not perfect. I'm still dialing it in this weekend.
FZR600 RA
D&D full exhaust with no baffle(WAY LOUD)
Stock airbox.
Factory Pro springs.
Factory Pro needles clip position #2.
Float Height 24 mm.
mixture screws 2.25 turns out.
Stock jets 107.5 main
This setup seems just a touch lean at 1/8 to 1/2 throttle . I'll edit the post as I get it closer to perfect.
Remember all who are working on your carbs, record every change so you don't have to repeat anything.
Factory pro pages
CV carb tuning
http://www.factorypro.com/tech_tuning_p ... gines.html
A good explanation of adjusting floats w/pics
http://www.factorypro.com/tech_tuning_p ... edure.html
MIkuni Carb explanation
http://www.iwt.com.au/mikunicarb.htm
Happy tuning guys
:cheers:
Re: List your carb setup
Posted: Fri Aug 22, 2008 9:32 pm
by megaloxana
I wonder if we can get factory pro's database posted on here? They should have a good number of setups in their database for the fzr.
Posted: Fri Aug 22, 2008 9:48 pm
by haro504
i ahhhhhhh have 4 yep 4 carbs
Posted: Fri Aug 22, 2008 10:18 pm
by YAM93
dude is totally cracking me up tonight...
anyway, yeah, i DEFINITELY got 4, but i have no idea of their settings other than all the needles are at the 3rd position and they are by DYNOJET. I had a mechanic clean and tune them January of 2007 but don't know what he set the floats at or the mixture screws.
Maybe i'm going nuts but i thought there was a "carb sticky" or wiki for this kind of stuff anyway. i shall look around.
:twisted: :rocker: :drumroll
Posted: Fri Aug 22, 2008 10:36 pm
by ragedigital
Bike: 1996 FZR600 (EXUP - all EXUP components removed)
Intake: Stock Airbox w/ K&N Filter (no ram air tubes attached to frame)
Exhaust: Full V&H Supersport Exhaust
Carb Mods:
- Factory Pro Emulsion Tubes
- DynoJet Jet Kit
Carb Settings:
- Main: 126 (DynoJet)
- Starter: 52.5 (Stock)
- Clip Position: #3
- Float Level: 22.5mm
- Mixture Screws: Varies. Got them as close as possible with a IR Temp Gun taking header measurements.
Notes:
Did not drill out slides like DJ recommends.
I run 87 octane gasoline.
Not the best all-around town settings, but it was a Track Day beast! Pulled real hard at 1/4 to WOT.
Posted: Sat Aug 23, 2008 12:13 am
by slayermd
Still stock :(
Posted: Sat Aug 23, 2008 12:24 pm
by davephipps
I'm going to record all of these and see if ragedigital will add them to the wiki. Please post more guys, I need all the info I can get.
BTW slayermd are you in the seattle area, and working in game development?
Posted: Sat Aug 23, 2008 2:50 pm
by maverick
i'm still dialing it in but as of now i have the cold air intake with a dynojet stage three jet kit. 128 mains with 24mm float height and needles on clip 2. i think 3 turns out for idle air screw.
Posted: Sun Aug 24, 2008 1:45 pm
by fadlan12
Currently bike is stock, V&H ehxaust and paper filter (soon a K&N).
My carbs settings:
22mm floats
3.5 a/f
synched
setting 3 (from the top) on factory pro needles
new emulsion tubes
factory pro springs
stock jets 7.5,5.2 etc
Running super unleaded most of the time.
Posted: Sun Aug 24, 2008 3:01 pm
by slayermd
davephipps wrote:I'm going to record all of these and see if ragedigital will add them to the wiki. Please post more guys, I need all the info I can get.
I am not in the Seatle area. Im in good ole' Denver. And I wish I was in game development, that would be sweet!
Posted: Sun Aug 24, 2008 3:58 pm
by fadlan12
YAM93 wrote:^^^
think thats in the archives
Posted: Sun Aug 24, 2008 5:05 pm
Posted: Sun Aug 24, 2008 5:56 pm
by fadlan12
But none of these details are there, I had suggested this a few weeks ago when you guys posted about it.
viewtopic.php?f=32&t=1098
Posted: Thu Aug 28, 2008 12:52 pm
by davephipps
C'mon people. It's hard to create a reference for people without a good sampling. I know there are more people out there with carbs on thir bikes. List them and the FZR gods will smile down upon you and grant you 10 more HP 8-)
Once we have enough perhaps Rage can add the refs to the wiki.
