List your carb setup
davephipps
Post by davephipps »
I've seen quite a few posts on this forum asking for Carb help. I was thinking that it might be useful to list our working carb setups.
I'll start. Mines not perfect. I'm still dialing it in this weekend.
FZR600 RA
D&D full exhaust with no baffle(WAY LOUD)
Stock airbox.
Factory Pro springs.
Factory Pro needles clip position #2.
Float Height 24 mm.
mixture screws 2.25 turns out.
Stock jets 107.5 main
This setup seems just a touch lean at 1/8 to 1/2 throttle . I'll edit the post as I get it closer to perfect.
Remember all who are working on your carbs, record every change so you don't have to repeat anything.
Factory pro pages
CV carb tuning
http://www.factorypro.com/tech_tuning_p ... gines.html
A good explanation of adjusting floats w/pics
http://www.factorypro.com/tech_tuning_p ... edure.html
MIkuni Carb explanation
http://www.iwt.com.au/mikunicarb.htm
Happy tuning guys
:cheers:
FZR600 1992
CB550F 1974
GL1000 1978
megaloxana
Re: List your carb setup
Post by megaloxana »
I wonder if we can get factory pro's database posted on here? They should have a good number of setups in their database for the fzr.
haro504
Level 7.5
Level 7.5
Post by haro504 »
i ahhhhhhh have 4 yep 4 carbs
YAM93
Post by YAM93 »
dude is totally cracking me up tonight...
anyway, yeah, i DEFINITELY got 4, but i have no idea of their settings other than all the needles are at the 3rd position and they are by DYNOJET. I had a mechanic clean and tune them January of 2007 but don't know what he set the floats at or the mixture screws.
Maybe i'm going nuts but i thought there was a "carb sticky" or wiki for this kind of stuff anyway. i shall look around.
:twisted: :rocker: :drumroll
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
Bike: 1996 FZR600 (EXUP - all EXUP components removed)
Intake: Stock Airbox w/ K&N Filter (no ram air tubes attached to frame)
Exhaust: Full V&H Supersport Exhaust
Carb Mods:
- Factory Pro Emulsion Tubes
- DynoJet Jet Kit
Carb Settings:
- Main: 126 (DynoJet)
- Starter: 52.5 (Stock)
- Clip Position: #3
- Float Level: 22.5mm
- Mixture Screws: Varies. Got them as close as possible with a IR Temp Gun taking header measurements.
Notes:
Did not drill out slides like DJ recommends.
I run 87 octane gasoline.
Not the best all-around town settings, but it was a Track Day beast! Pulled real hard at 1/4 to WOT.
slayermd
Level 5.0
Level 5.0
Post by slayermd »
Still stock :(
davephipps
I'm going to record all of these and see if ragedigital will add them to the wiki. Please post more guys, I need all the info I can get.
BTW slayermd are you in the seattle area, and working in game development?
FZR600 1992
CB550F 1974
GL1000 1978
maverick
Post by maverick »
i'm still dialing it in but as of now i have the cold air intake with a dynojet stage three jet kit. 128 mains with 24mm float height and needles on clip 2. i think 3 turns out for idle air screw.
fadlan12
100+ Posts
100+ Posts
Post by fadlan12 »
Currently bike is stock, V&H ehxaust and paper filter (soon a K&N).
My carbs settings:
22mm floats
3.5 a/f
synched
setting 3 (from the top) on factory pro needles
new emulsion tubes
factory pro springs
stock jets 7.5,5.2 etc
Running super unleaded most of the time.
slayermd
Level 5.0
Level 5.0
Post by slayermd »
davephipps wrote:I'm going to record all of these and see if ragedigital will add them to the wiki. Please post more guys, I need all the info I can get.
I am not in the Seatle area. Im in good ole' Denver. And I wish I was in game development, that would be sweet!
fadlan12
100+ Posts
100+ Posts
Post by fadlan12 »
YAM93 wrote:^^^
think thats in the archives
sweekster
Post by sweekster »
fadlan12
100+ Posts
100+ Posts
Post by fadlan12 »
But none of these details are there, I had suggested this a few weeks ago when you guys posted about it.
viewtopic.php?f=32&t=1098
davephipps
C'mon people. It's hard to create a reference for people without a good sampling. I know there are more people out there with carbs on thir bikes. List them and the FZR gods will smile down upon you and grant you 10 more HP 8-)
Once we have enough perhaps Rage can add the refs to the wiki.
FZR600 1992
CB550F 1974
GL1000 1978
