No clue what I'm doing
Posted: Wed Dec 09, 2015 1:22 pm
by muchluv4lyrics
Re: No clue what I'm doing
Posted: Thu Dec 10, 2015 2:55 pm
Yes. That said, the aftermarket inline fuse to the hot terminal and the "insulated" crimp terminal on the negative terminal wire bodes ill for the condition of the rest of your harness ... Check your fuses and the condition of your voltage regulator; once it's a bit more together you can do a coil check (does the problem stay on 1-4, or does the problem move to 2-3 when you swap primary coil leads. You may have a damaged ignition box.
Posted: Tue Dec 15, 2015 12:52 am
by evan_calgary
You have a multimeter? Check battery voltage if you do after charging for it bit. Its likely toast. Try a vehicle battery if you want to check as well. Like Don said, you best bet for diagnosis if to switch the coils. If you don't have a multimeter you will need to pick one up for this most likely. They are cheap and easy to use. WIring problems can be a pain, just keep at it and print off a wiring diagram (in color!).
Posted: Tue Feb 23, 2016 12:14 am
by TomJ
First. We must be kin! I've done the same thing in my kitchen (and had to park my old Triumph inside my living room on a large auto oil pan, to keep the bike from getting stolen).
Next, Harbor Freight for a cheap multitester (or if you actually have money, go to Grainger and get a Fluke - had mine for 30+ years now). Check batt, then do as the others have said. Suspect a coil if 1-4 not firing and they do when you swap leads (or just one to the adjacent, non-firing cylinder). Or, one of the drivers is burned out on the board of the ignitor. Easily repairable with soldering in a new transistor. Or get an ignitor box from a cycle scrap yard.
First batt though. I have two good FZR batts sitting on a solar trickle charger, perfect condition. If you were close, I'd toss you one. Cheap ones can be had at Wally world though (if your main prob is indeed the batt - I suspect it's more than one issue though)
