Help with engine case issue
Posted: Wed Oct 28, 2015 7:01 pm
Hello guys and gals. Like the title states, I have a slight issue/question. My 99 fzr600 broke the clutch pushrod and seal before I bought her. That was the reason for selling he bike because the owner couldn't find the parts. So I got her cheap and bought the parts. The ball bearing is still on the clutch cover so I left it alone. Now, the pushrod gouged the lower case a bit more towards the outside of the case where the seal goes. The is the slightes of play but nothing more and everything seems to fit in place along with the seal. So my question is if I should get a replacement lower case? Maybe just epoxy or marinetec the one I have just to feel better? Never had an fzr before so I don't know how it should be from the factory? Is a little bit of play ok? Is the fitment tight where it goes? Engine cases are not aluminum and can't be welded but with the epoxy and some fine filing would it be fine? Thanks and hope someone with more experience with these engines can help... Will try to post a pic when I take one tomorrow...
Marcos...
Marcos...
