Need some advice on voltage regulator replacement
Posted: Wed Sep 09, 2015 9:36 am
This is regarding an 89 FZR 600 that I bought a few months ago.
I've been dealing with a random stalling issue that I am pretty sure is electrical. I'll be riding along, and suddenly the bike is stalled. Usually there's no warning, though now and again, there's little/no throttle response right before it happens. After it happens it won't restart immediately, but will if I wait a few minutes. A couple of times, it's refused to start when cold. Fuel is very fresh, non-ethanol fuel treated with sea foam. I have an electric petcock that is working properly, and the fuel pump is new (and working properly). Fuel filter is also new. Just covering all of the bases here... but I really don't think it's fuel related.
I pulled the body work off for the first time, and noticed that the voltage regulator is absolutely fried. It's a melted mess. I'm surprised it works at all. It needs to be replaced, and that's where I've run into a bit of a brick wall. My questions are as follows...
1) Could the voltage regulator failing be the cause of my stalling issues?
2) Given its condition, it needs to be replaced either way. It appears that the OEM parts are no longer available. I have my choice of used or aftermarket. The aftermarket stuff varies in price widely-- from less than $10, to more than $150-- and varying hugely in appearance as well. Can anyone recommend a particular vendor/part number? If I can get away with using one of the $10 options, that would be great... if I can't, I'll suck it up, but I have to imagine that I can get by without spending $150 on it either.
EDIT: Before anyone says it, yes, I have read the stickied thread... it's old, it doesn't list part numbers or suppliers, and I don't dare buy on appearances alone.
