only starting in neutral?
FZR_600_90
Post by FZR_600_90 »
I can only start in neutral it doesnt work in other gear when i press the clutch its annoying when the engine die at the stop sign
Re: only starting in neutral?
Check your clutch switch for security and function. Ensure the clutch throwout mechanism is properly adjusted. Set your idle speed in neutral on a fully warmed engine.
FZR_600_90
My clutch cable broke down last ive replaced it maybe i did something wrong when ive install it ?
Possibly. Again, check the throwout adjustment, and do a sanity check on the cable routing - are there any twists, kinks, or sharp bends?
