What sort of MPG are you getting from your 3HE?
I'm not getting the sort of range I was expecting from it, it seems a lot more thirsty than my 4JH.
Mind, I have been doing quite a bit of high speed test riding recently (100+ for extended periods), I guess the economy drops off somewhat in that case?
MPG?
Re: MPG?
Yes ... The faster the bike goes, the faster the gas goes. Bear in mind too that drag goes up with the square of your speed - double the speed, you face 4x the drag and need 4x the fuel to overcome it (assuming other factors don't also chime in).Biker_Bob wrote:I have been doing quite a bit of high speed test riding recently (100+ for extended periods), I guess the economy drops off somewhat in that case?
- Harrysf707
Re: MPG?
43 MPG average here, 75-80 MPH backroads/highways very little city. But, my jets are running retardedly rich...
Re: MPG?
When I say dropped from 50-55 down to 35-45, there's also a transfer from street to track. So, I was getting 50-55 on the street (very tame riding, shift around 5 or 6 and cruise around 3-4K) to 35-45 with Stage 1 and sprocket change on the track (keeping revs above 7K).
