Streetfighter headlight
Posted: Thu Jul 03, 2014 3:34 am
by scotty110788
Hi, I'm looking into a streetfighter headlight, problem is I have 2 lights, one for main and one for parking, the parking one is jus a bodge job of led strips which previous owner fitted. But is there anyway to convert them to a single headlight rather than 2? Or will I blow a fuse with a simple join up of the wires? For main there is 2 bulbs, 3 wires each, parking light is only 2 wires. Hope u understand my question thanks.
Re: Streetfighter headlight
Posted: Thu Jul 03, 2014 10:01 am
by Mikey
scotty110788 wrote:Hi, I'm looking into a streetfighter headlight, problem is I have 2 lights, one for main and one for parking, the parking one is jus a bodge job of led strips which previous owner fitted. But is there anyway to convert them to a single headlight rather than 2? Or will I blow a fuse with a simple join up of the wires? For main there is 2 bulbs, 3 wires each, parking light is only 2 wires. Hope u understand my question thanks.
The 3 wires to the 2 bulbs are Yellow (High beam) Green (Low beam) Black (Ground). The 2 wires to the Parking light are or should be Blue (Power) Black (Ground).
I'm guessing that your in Europe, In England you only need the parking light to be switched on if your parked at night on a road with a 40MPH Speed Limit or above, I'm not sure but I don't think you need a parking light for the MOT.
HTH
Posted: Thu Jul 03, 2014 12:04 pm
by scotty110788
Thanks for the reply, so to attach one headlight, do I jus ditch one side off wires or combine them for a single headlight? Well parking light wires are all over the shop and no longer have the correct colouring, also found 2 wires, blue/yellow, black/yellow on each but only 1 other one for them to clip into leaving one spare and no where t go?
Posted: Thu Jul 03, 2014 1:26 pm
by Mikey
scotty110788 wrote:Thanks for the reply, so to attach one headlight, do I jus ditch one side off wires or combine them for a single headlight? Well parking light wires are all over the shop and no longer have the correct colouring, also found 2 wires, blue/yellow, black/yellow on each but only 1 other one for them to clip into leaving one spare and no where t go?
Yup you only need to use 1 of the 3 wire connectors for a single Headlamp conversion. the Blue/Yellow & Black/Yellow wires connect or should connect to the clutch switch.
Here's a wiring diagram it's for USA models but should help you out
http://fzronline.com/wiki/lib/exe/fetch ... iagram.gif
GL
Posted: Thu Jul 03, 2014 4:29 pm
by scotty110788
Mikey wrote:scotty110788 wrote:Thanks for the reply, so to attach one headlight, do I jus ditch one side off wires or combine them for a single headlight? Well parking light wires are all over the shop and no longer have the correct colouring, also found 2 wires, blue/yellow, black/yellow on each but only 1 other one for them to clip into leaving one spare and no where t go?
GL
Thanks mate, here is wire in question, one male, but 2 females so one with nothing to attach to
Posted: Fri Jul 04, 2014 7:03 am
by Mikey
Looks like 2 Males and 1 Female to me, the White(Top) Male connector should plug into the Clutch switch, it's on the clutch perch (where the clutch lever is).
