hi, guys.
I'm going to spend a week with a friend who has fzr600 that's sat around a couple of years. He has almost no tools, and I'm flying so I can't bring my toolbox with all my wrenches etc., and I'd rather not go to Harbor Freight there. So, my objective is to bring as few tools as possible to get a fzr running!
I will be bringing a compression tester, a VOM, a multi head screwdriver, and a feeler gauge set. I need to know what size wrenches, socket heads, etc., etc., are needed to do a CPR. Lets make two bare minimum lists. One list to do a cpr, and another list if I have to do a valve job, too. BTW, I'm sure I'll have to clean the carbs.
Thanks a zillion!
BARE MINIMUM TOOLS FOR A CPR??
goosefartfan
Re: BARE MINIMUM TOOLS FOR A CPR??
double ended screwdriver
metric allen key pack
vise grips
seriously though 8,10, 12, 14 mm 1/4" drive sockets, a 1/4 drive ratchet, long extension, short extension, metric allen sockets 5,6,8,10mm, a good crescent wrench. box/open 10,12,14mm wrench, plug socket (or stock toolkit unit) and 3/8" to 1/4" adaptor, carb screwdriver, leave the comp tester at home(can rent one if necessary {prolly not} , or better yet rent a leak down test set),
vise grips
goosefartfan
thanks, RR, but i'm already gone.
got everthing but the carb screwdriver
