I bought a project bike about a week ago for pretty cheap. I'm pretty sure most of the important wiring issues are fixed now. However when I got it the throttle cable weren't attached could some one snap a pic of how the cables attach to the bracket in the carbs? Or point me in the direction of one? Thanks
After I get this figured out it's put the chain back I'm and ride!
Throttle cable bracket
- willandrip
- Level 7.0
Re: Throttle cable bracket
3EN2; but the carbs/cable fit are identical.
Thanks but my push cable isn't threaded in that end to lock it I to place in the bracket like that. It looks the same as other cables I have seen being sold online as push cables though. I think I might just modify the bracket to use a different clamp and call it close enough. I'd rather not buy a new cable.
- willandrip
- Level 7.0
Yes; it is always much better to alter the bracket on a precise piece of equipment such as a bank of carburettors rather than spend $13 to buy the correct cable.
It is only the return cable after all and if it jams at full throttle nothing much can go wrong !
Good luck with your endeavour.
