I can`t be sure if I allready had the problem before the rebuild as the front was in quite horrible condition, so it could have been there for a while but I just hadn`t noticed it.
I´m pretty sure I installed everything back to their places, or atleast I didn`t end up with any "extra"-parts...
The forks are set to same height within 1mm, so that shouldn`t be the case here, nor do I think I could have tightened the axle so much that it would have thin kind of affect ( think that would need huge over tightening).
The wobble was worse when the preload was excessive, also I think it helps when I brake so that the front dives little deeper into the
lower part.
I´ve been thinking about few things that could cause the problem
1. Wheel bearings may be nearing their end.
2. Wheel could be too un-balanced. ( I know for sure they weren`t balanced when the tyre was last changed, but it was done 5000km ago.)
3. The nylon(?) bushings inside the forks could be worn out. ( In this case shouldn`t there be some wobble all the time?)
More advices would be appreciated
