turbo 1994 fzr 600
Posted: Wed Apr 09, 2014 7:43 am
by tino082895
Hi. Im a new member to the forum. I need help locating the proper spot to tap my pressures oil lines for my t25 Gerrett. The turbo is located above the oil filter. Help??
Re: turbo 1994 fzr 600
Posted: Wed Apr 09, 2014 6:20 pm
by tino082895
Opps Garrett*
Posted: Wed Apr 09, 2014 6:32 pm
by reelrazor
I'd tap into the external oil feed lines to the cam bearings on the pressure side..they're external...and right there where you need them
Return side will be the toughie...have to get it back to the sump...cam bearing supply naturally runs down the chain well to the sump..any port back crankcase internal will work, but you'll have to drill and tap one for yourself.
Posted: Thu Apr 10, 2014 6:34 am
by riturbo
tino082895 wrote:Hi. Im a new member to the forum. I need help locating the proper spot to tap my pressures oil lines for my t25 Gerrett. The turbo is located above the oil filter. Help??
Welcome Post some pics of this turbo fzr :nopic :tks:
Posted: Thu Apr 10, 2014 9:02 pm
by FZR_600_90
i have a t25 home laying around that would be interesting !
