Page 1 of 3
help needed. hit a road block.
Posted: Mon Nov 18, 2013 8:47 pm
by tclayton9
I'm in the process of getting stuff ready for paint. My rear axle is either seized or bent. u lubed it up and beat the hell out of it with hammers, pipes, and anything that was solid and heavy. it only moved enough for the axle to dissapper on one side of the swingarm. I don't know what else to do and the shop wanna charge 70 dollars an hour.
also I'm doing my fork seals. I got the snap rings out and I loosed the bolt counter clockwise at the bottom of the fork and it still isnt coming apart. what am I doing wrong.
Re: help needed. hit a road block.
Posted: Tue Nov 19, 2013 9:22 am
by M in KC
This should be all you need to know regarding replacing fork seals. http://www.fzrarchives.com/ipb/index.ph ... opic=22544
As far as the rear axle is concerned try keeping your rear wheel as straight as you can while trying to remove it. There really isn't anything magical back there. Wish I had a better answer here.
Posted: Tue Nov 19, 2013 12:24 pm
by pefrey
If you need that much force to remove your rear axle, you are doing something wrong. As mentioned, try taking the weight off of the axle.
Although the bolt may be turning on the bottom of your forks, the damper rod on the inside is probably also turning. Make sure the damper rod is removed. The link provided is a good one.
When I separated the upper and lower forks (tube and slider) I put the front axle through the fork lower, then sat on the ground with my feet on the axle and the slider (chrome tube) in my hands and pulled, pushing on the axle with my feet at the same time.
Posted: Wed Nov 20, 2013 10:18 am
by M in KC
Did you manage to get the rear axle out.?
Posted: Wed Nov 20, 2013 4:03 pm
by tclayton9
nope still no luck. I've tried everything.
Posted: Wed Nov 20, 2013 7:47 pm
by M in KC
dayum sorry to hear that. How about throwing up some pics of what you have going on maybe some will see something that can help.
Posted: Sun Nov 24, 2013 2:57 pm
by tclayton9
I found out what I'm going to do. I will cut the swing arm about an inch above where the axle goes into the the chain guides. take off what I can and beat the hell out of the axle. I don't need the swingarm because somebody screwed up trying to extend it. and I'm not paying a shop 70 dollars an hour when I can cut my my extended swingarm and buy a used one and an axle off eBay for 50 dollars.
Posted: Sun Nov 24, 2013 5:37 pm
by dash
Are you holding the ass-end of the bike in the air?
Posted: Sun Nov 24, 2013 6:15 pm
by tclayton9
I have the swingarm off. its just swingarm dog bones and wheel.
Posted: Mon Nov 25, 2013 9:01 am
by dash
Does the axle bolt turn?
Posted: Mon Nov 25, 2013 1:10 pm
by M in KC
Heck if that's all it is now, leave it at the curb and hit Nate up for a YZF swingarm/17' rear wheel swap and be done with it. His packages are a drop-in.
Posted: Mon Nov 25, 2013 1:43 pm
by dash
if it turns, put it in the freezer.
Posted: Mon Nov 25, 2013 2:35 pm
by tclayton9
yes it turns
Posted: Mon Nov 25, 2013 4:55 pm
by dash
it might loosen up enough if you can freeze it? i don't know what the coeff of linear expansion is for steel but you might get a few 0.001s to deal with?
Posted: Mon Nov 25, 2013 8:03 pm
by tclayton9
how can I freeze it
