VR placement?
Posted: Fri Sep 20, 2013 3:05 pm
So i had to relocate the VR because my rear end got fractured and i had to cut it off and make an aluminum box custom to fit the new shape. There was no air flow in there and got hot as hell! so i re routed it to the front of the bike hidden inside the front fairing underneath the headlight housing. Seems to be working for now, staying cool up there. The issue i have is that everywhere i read i see special brackets to disperse the heat. Do i need the bracket or am i okay with it where it is staying cool and away from moisture and debris.
Thanks in advance.
Thanks in advance.
