Headlights not working
Posted: Fri Aug 23, 2013 12:29 pm
Hey all;
I have a 1994 Yamaha FZR600 that has a set of headlights that don't function. High/low beam = no go. Bulbs are fine, both work on high and low beam. Turn signals all function fine. Brake lights function fine. Bike is running while testing & the two front turn signals act as running lights - I'm aware.
Someone suggested a poor ground but I checked all the connections, turn signals, rear brakes, bulbs (bad filaments) and they're all good. I believe a poor ground would also affect other lights, not solely the headlights? The only thing left that I can think to check is the high/low beam switch on the clutch side. I haven't taken that off yet as it looks like someone stripped the screws and I've not go replacements.
Really appreciate any suggestions!
Thanks,
Thanks,
