New here, No Start! help
Posted: Thu Aug 15, 2013 12:30 pm
Hey everybody,
To start, new to FZR's but not to bikes. Im a DIY'er into restoring cars, bikes, mopeds, older stuff, etc.
The Bike is a 1992 FZR 600.
Picked her up non-running for 4 years, the owner swore that she was well cared for prior to a 4 year storage.
I cant get her to start!
Got a new battery, oil & filter, spark plugs, new starter solenoid, cleaned the carbs, cleaned out the gas tank and petcock, cleaned the air filter (UNI foam), pulled apart the grounds & connectors and cleaned them, pulled apart the controls and cleaned them, Still no start.
Here's what happens: I turn the key and the headlight and neutral light come on, I flip the kill switch to RUN & the Oil light comes on, the fuel pump primes the carbs, the EXUP servo cycles. I press the START button (in neutral, kickstand down, no clutch), the headlight turns off, and the Oil light turns off, but nothing from the starter...
So I jump the starter to make sure it cranks, It does! But the motor doesn't catch, just cranks.
So I'm thinking I have 2 issues here:
1. There's discontinuity between the START switch and the Starter...
2. Something is keeping the motor from starting when the starter is jumped.
I checked for spark by removing a spark plug and grounding it to the frame. It looks pretty weak, so I pulled off the plug caps, disassembled, and cleaned them in solvent. Cut a tad off the wires to make a fresh connection w the caps.
Question: Does the resistor go in the cap before, or after, the spring? does it matter? I put the spring in first.
I'm thinking about picking up new NGK SD05F plug caps after some more diagnosis this evening.
Picking up a new multimeter today also.
HELP pls
HELP pls
