660 carb question
Posted: Sun Aug 11, 2013 4:37 pm
by JeCarter
Ok so I'm trying to figure out everything I need for the 660 build. Say I go with the yzf head what carbs should I use? The tps carbs have me confused. How would you use the tps or could you just bypass it. And could I use the fzr head with yzf con rods?
Re: 660 carb question
Posted: Sun Aug 11, 2013 4:51 pm
by reelrazor
YZF conrods requires the use of a spacer (roughly 3mm thick underneath the cylinder block. This also changes the cam timing, so adjustable cam sprockets are required.
I used teh FZR carbs, fzr head, and fzr rods bored at the small end to fitthe yzf wrist pins. yzf cylinders and pistons. YZF base and head gasket.
That's it, complete parts list needed if you have a complete running FZR engine already
Posted: Mon Aug 12, 2013 4:42 am
by JeCarter
Thanks reelrazor
How many miles have you racked on your build now? And what was the jetting you used on the stock head?
Posted: Mon Aug 12, 2013 7:39 pm
by reelrazor
I have about 5,000 miles on it.
Not stock head, ported FZR head with megacycle cams (x3, x5 I can't remember which grind at this moment), and their double coil spring and titanium keeper set.
I ended up with 125 mains, the big pilots (from the FP kit, #35??), needles one clip higher than center, float level at 23mm
Posted: Thu Aug 22, 2013 5:23 pm
by FZR_600_90
What year yzf piston should i look for ? 1997 would be ok ?
Posted: Thu Aug 22, 2013 7:52 pm
Don't know that it makes a difference. While the 4JH and 4TV models use different p/ns for the pistons and crank, the piston rings, wrist pins, con rods, bearings and cylinder blocks are all the same, so they can't be THAT different ...
Posted: Fri Aug 23, 2013 4:23 am
by JeCarter
Mine are from 2000. Most of the pistons on eBay are the 4tv pistons which is what I've read I needed.
Posted: Fri Aug 23, 2013 8:01 am
by FZR_600_90
Cause i find one in my area for not much, might pick it up this weekend
Posted: Sat Aug 24, 2013 8:11 am
by JeCarter
Go ahead and buy. Good luck man.
