Does anyone know where I can pick up the hex bolts for the sprocket? or what the dimensions and threading is on them?
I have to replace the front sprocket and lock tab and nut but the bolts on the cover are stripped and need replacing too.
Sprocket Cover Bolts
'97 FZR600
Re: Sprocket Cover Bolts
4x 91317-06040-00 Bolt; MSRP $1.99 ea at your local dealer.
1x 91317-06050-00 Bolt; MSRP $1.88.
The shipping costs would eat any savings vs an online vendor, unless you get your sprocket etc from the same bunch. Since you're also getting the following:
1x 90179-18020-00 Nut, Special Shape; MSRP $8.49
1x 90215-21290-00 Washer, Lock; MSRP $3.95
places like Partzilla and BikeBandit start to become a little more attractive.
Marine, maybe thatkid (nate) can help, you might be able to add some of his powder coated bling.
My FZR6 Rebuild
My FZR6 Rebuild
