front brake question
Posted: Sat Jul 13, 2013 6:25 pm
by tclayton9
okay so my stock front master cylinder has a leak. I was wondering when I use a r6 front master cylinder can I keep the front FZR calipers and lines and run the master cylinder to the one line using a smaller banjo bolt, or I have to use two lines like on the r6.
Re: front brake question
Posted: Sat Jul 13, 2013 7:13 pm
Yes. Use the FZR banjo bolt, but be sure to get new copper crush washers.
Posted: Sat Jul 13, 2013 8:13 pm
by tclayton9
OK that was my solution. But how many washers would I need.
Posted: Sat Jul 13, 2013 8:15 pm
If you're only replacing the M/C, then you'll only need two - one on either side of the hose.
Posted: Sat Jul 13, 2013 9:03 pm
by tclayton9
Gotcha thanks.
