ignition won't turn after getting out of "Lock" position
Posted: Mon Jul 01, 2013 4:46 pm
by Harrysf707
So, I put my bike in the "Lock" position (in my garage) after getting back from a short ride, took the key out and didn't come back until 2 hours later. Took the key, put it in, and turned it to the "Off" position.. Now the Key won't turn to the "On" position or go back to the "Lock" position. I've sprayed WD-40 in the ignition and worked the key in and out and tried wiggling it...still nothing. Am I doing something wrong here? I've tried it with the main key and the spare key still doesn't work. Anyone ever had a similar problem?
-Thanks
Re: ignition won't turn after getting out of "Lock" position
Posted: Tue Jul 02, 2013 1:52 am
by JohnBoy69
Has the steering lock released?
Posted: Tue Jul 02, 2013 3:53 am
by Harrysf707
Yeah, the steering lock is disengaged. I can move the handle bars back and forth. The wd-40 as of now, has been sitting there for 7 hours now..still no luck...
Posted: Tue Jul 02, 2013 5:08 pm
by Harrysf707
Update:
Removed and brought the ignition tumbler to a locksmith, apparently the tumbler was damaged. I don't know how..so I switched the tumbler with the spare one I had..problem fixed. :)
