I under the mirror from YZF600 is a direct fit but I found a 1997 YZF 750 mirror and wondering if they would fit my 94 fzr600. I'm trying to get the seller to measure the distance between the mounting holes. Would anyone happen to know what the distance to the holes are for our FZR600?
Thanks a bunch for any help
yzf750 mirror compatible
Re: yzf750 mirror compatible
You can always swap the bases. If they don't fit.
My FZR6 Rebuild
My FZR6 Rebuild
Ok, I just got confirmation from the seller that it is 2 inches bolt hole to bolt hole so I think it should be a good fit.
Thanks,
Thanks,
You're right, I could just swap out the base, Thank you for the advice
