How to tighten clutch and throttle cables 99 fzr 600
Hey guys, how do I tighten my clutch and throttle cables on my 99 fzr 600?
Re: How to tighten clutch and throttle cables 99 fzr 600
With the adjusters ... ?
Haha, yup Don is correct.
Both the Throttle and Clutch can be adjusted in two places. Both have a Lever adjuster which is the easiest and unless it's already maxed out should be fine to adjust the throttle.
However the clutch is a different story, and proper adjustment is very important.
"First, loosen the adjuster and the hand lever.
Then, remove the lower left fairing.
On the front of the sprocket cover there's a round black rubber cap. Remove it.
Under it you'll have a, I wanna say 12mm, nut; loosen it. Turn the phillips screw until the slightest bit of resistance is felt.
Turn it out again and tighten once more until the slightest bit of resistance is felt, then back out a 1/4 of a turn. *Important!
Tighten the nut without moving the screw, check for free play at the hand lever, adjust as needed."
Failure to do this properly will result in Clutch Rod failure; So do it correctly!~ Pay attention
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Thanks guys! I'll follow the directions and see how it works.
