the clucht. What can it be?. The neutral light goes out when the first geared.
A LITTLE HELP
yamarossi46
A LITTLE HELP
Please, a little help. My yam fzr 600 year 92 model 3hj as been six years now stop. Start ok, but while meshing the gears the bike does not move when you release
Thank you very much.
Re: A LITTLE HELP
Does the clutch handle/lever return easily after pulling it in? The only thing that would cause that I can think of is if the clutch is stuck after pulling it on to shift gears then it stays engaged. Is the clutch hydrualic or cable?
yamarossi46
Re: A LITTLE HELP
Firts..thanks for your help. Well...the clutch is for cable. The handle /lever return after pulling. But whit the first example gear engaged, loose and the bike handle or forward or stalls. Have something to do clucht sensor?
Re: A LITTLE HELP
Check your sidestand switch.
- Fizzinatorr
- Level 6.5
Re: A LITTLE HELP
Also make sure the sidestand isn't down
yamarossi46
Re: A LITTLE HELP
Hello. Thanks for your help. But my mechanic, says ....seems a problem of clutch...wich will operate.
