Brake lights stuck on (98 FZR 600)
Posted: Tue Jun 04, 2013 11:32 pm
by JB_fzr600
Hey guys, my 98 fzr 600 taillight is stuck In the on position. It will not flicker from the front or rear brake when applied. Has anyone had this issue? If so, what do I do? HELP!!!
Re: Brake lights stuck on (98 FZR 600)
Posted: Wed Jun 05, 2013 12:41 am
by Harrysf707
Check the rear brake switch, sometimes it likes to get stuck in the "on" position. Should be located behind the right heel guard. Lube it with some WD-40, you might have to loosen/ lower the rear brake if that doesn't work.
Posted: Wed Jun 05, 2013 9:44 am
by JB_fzr600
Thanks man. Now do I have to remove my rear brake and foot assembly to do it or can I do it without removing it?
Posted: Wed Jun 05, 2013 12:05 pm
by Harrysf707
You should be able to do it without removing it.
Posted: Thu Jun 06, 2013 9:28 am
by tjs5443
the switch is right behind the heel guard. two bolts that hold it on are all you need to remove. the switch just hooks into the rear brake lever and can be adjusted via the plastic nut type thing thearded to the switch. the switch just pops into the hole behind the heel guard. If you find that the rear brake switch is not the culprit then it is likely that the front brake switch is at fault. you can see/hear the switch moving where the brake lever meets the master cylinder when u pull the lever.
Posted: Thu Jun 06, 2013 2:26 pm
by pefrey
Are you sure the rear brake lights are on, or are they off and your brake lights don't work?
