blown gasket maby and lost my clutch??
Jeffm93fzr
So I was driving down the highway and I go to take my exit and i realised I didn't have a clutch, there was no tension on it and when released it just stayed in there wss no tension to pull it back out so I clutchless shift to first and found a curb to ride up on there was no sholder so I rode it in that little raised triangular area you find sometimes when u exit a highway and killed it I get off and there is oil all over my rear tire shock and the bottom of my motor so I'm guessing whetever happened to my oil caused my clutch to not work I took off my front sprocket cover and everything looks in place for my clutch being in an apt I can work on it here will have to take it somewhere else just wondering if anyone had any idea how losing oil which I'm guessing is a bad gasket could cause me to have no clutch if anyone has any ideas please let me know if you have any questions of anyrhing I'm leaving out let me know ill answer the best I can
Re: blown gasket maby and lost my clutch??
Under your Front Sprocket cover is the Clutch Push Rod; I have a feeling this has failed somehow and the Push Rod Seal has failed along with it.
If this seal fails it will shoot oil out the front sprocket cover, onto your chain and all over your rear wheel. My guess is your Push rod snapped.
In the pic below: The Push Rod is sticking out in front of the sprocket and you can see the black seal around it. Check it out.
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Jeffm93fzr
I finally got a chance to check everything out today and my push rod did snap I was just thinking about it at work and it just hit me and when I got home I checked it out and sure enough I was right thank you for the picture and reply I didn't realise I was missing my seal to now to find a push rod
