Hi folks,
My first time write at this forum. Have some problems with my fzr 600 89.
When i start it in free the neutral lights and the engine starts. but when i stop the engine and will start it second time the neutral light dont light and the engine wont run "/
Only change gear oil, K&N filters and coolant...
Any advice to what this could be??
Friendly regards
Ole
Wont start
Re: Wont start
Try this: If the Neutral light is not on: Sit on the bike, Pull in the Clutch Lever, Put the Kickstand up, and Try to Start the bike.
If neutral light is not on, and the kickstand is down, the bike it will not start.
Hope this helps
Hope this helps
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Re: Wont start
How are you stopping the engine? Key switch, Run/Off switch, other.? It could be one of two things both are common failure points on the FZR's. First it could be your Run/Off switch. The contacts in this switch have been known to corrode and provide intermittent performance. Open the clam shell on the right clip-on and inspect and clean as necessary the switch's contacts. Secondly, it could be the side stand safety switch. This switch also is prone to failure due to its location. Road debris and such can compromise its operation. Take a look at it as well. Some times cleaing all the road debris off the switch's mechanism/contacts will make it functional again.
Re: Wont start
When i stop the engine i always use the key switch
