95 FZR600R TPS
Posted: Sun May 26, 2013 10:11 pm
by FiZzeR SEX HUNDRED R
Bought this 95 FZR600R and I'm in the process of restoring it, at some point before I owned it someone chopped off the wires for the throttle position sensor. I was told by a local bike shop that this sensor cannot be replaced and that I have to buy a new set of carbs.
I don't believe that, I think they were just trying to get more money out of me.
Anyone know where I can purchase a sensor and pigtail lead?
...and yes I've already tried online searches (including bike bandit), I think this is more of a junk yard part then something i can order online.
Re: 95 FZR600R TPS
Posted: Sun May 26, 2013 10:27 pm
Picture of the sensor, I'll take a better one when I get a chance.
https://sphotos-b.xx.fbcdn.net/hphotos- ... 8827_n.jpg
Re: 95 FZR600R TPS
Posted: Mon May 27, 2013 12:40 am
Ok - lots of confusion going on around here. The '95-96 4JH YZF600 / FZR600R didn't have a TPS; that was the '97+ 4TV models. Given that you're referring to it as a FZR600R (the UK designation), yet your location is Florida, I'm not entirely sure what you have.
That said, the part number for an easily replaced TPS for a '97 ThunderCat is 4TV-85885-00-00. The best price locally for a new one is
Partzilla at $183 + shipping. There's on on
Ebay right now for $26 + $13 shipping from Ireland.
Re: 95 FZR600R TPS
Posted: Mon May 27, 2013 1:23 pm
I appologize for he confusion, I'm new to Yamaha's. I was told it is an FZR600R but it may just be a 600. It's not a true TPS because it's a carbourtaed bike, it's a sensor I was told, by the local bike shop here, is used to control spark advance.
Re: 95 FZR600R TPS
Posted: Mon May 27, 2013 1:27 pm
A TPS is a TPS, whether it adjusts fuel-air mix in an EFI bike or just spark advance. I say again, the '95 4JH didn't have a TPS - of any sort - while the later model did.
It's entirely possible you have a Frankenbike, also known as a "Bitsa" - bitsa this bike, bitsa that bike ...
If that's a 4TV carb rack on a 4JH machine (with a 4JH ignitor box that doesn't know what to do with a TPS input), then it does make sense that the TPS wires are trimmed off, and there is no point in trying to replace the TPS.
Re: 95 FZR600R TPS
Posted: Mon May 27, 2013 2:48 pm
Thanks for the info, that actually makes alot of since for it to be pieced together. It had a custom coil setup on it, a toggle switch for the fan, and the voltage regulator doesn't match the one they show on bike bandit.
