Speedometer and tachometer question
While driving down the road I noticed my speedometer and tachometer stopped working all at once. When I pulled over I noticed the cable had come off. Does the cable work both tachometer and speedometer. Or does it run just the speedometer.
Re: Speedometer and tachometer question
The cable leading to the front wheel is just for the speedo. The tach is electrically driven by the TCI box.
how can I fix it.
