How can i deep clean my chain?
Posted: Sat Mar 23, 2013 11:59 am
by desmarat
I have the chain pulled off right now and was wondering if there was a way to give it a extra deep clean? I have herd of dips and boiling, any ideas of advice would be appreciated? Thank you!
Posted: Sat Mar 23, 2013 12:46 pm
by Redoliander
Put it in some kerosene and use a grunge brush or a toothbrush to clean all the gunk off.
Re: How can i deep clean my chain?
Posted: Sat Mar 23, 2013 12:53 pm
by desmarat
Okay thanks, should i let it soak in the kerosene for any time before scrubbing? Should i wash it off after with anything or just dry and wax?
Posted: Sun Mar 24, 2013 12:42 pm
by Redoliander
You can let it soak. After you clean it you can dry it with a rag then trow wax on it or wash it and let it dry then wax it. It's usually said its best to warm the chain then wax it. Not sure how important it is though. I use duponts Teflon chain wax. Works good with minimal fling off.
Posted: Sun Mar 24, 2013 1:18 pm
by pefrey
Did you mention boiling? Holy cow that sounds bad.
As mentioned, soak in kerosens an brush off the gunk.
Posted: Sun Mar 24, 2013 1:47 pm
by Kenny two guns
Soak in kerosene overnight. Let it drip dry for a half hour after scrubbing, the kerosene dries/evaporates quickly. Also Kerosene is used because it does not hurt the O-rings & X-rings in the chain. Unlike introducing boiling water or wd-40 to the chain..
Posted: Sun Mar 24, 2013 3:35 pm
by desmarat
Awesome, thanks guys! Ill go get a can of kerosene and get to it.
Posted: Thu Mar 28, 2013 8:51 am
by KaspenOne
i heard pinesol and a lil water works great and dont damage the o rings, just make sure to dry it off before spraying your lube on it ;)
Posted: Thu Mar 28, 2013 8:52 am
by KaspenOne
Posted: Thu Mar 28, 2013 3:03 pm
by willandrip
desmarat wrote:I have the chain pulled off right now and was wondering if there was a way to give it a extra deep clean? I have herd of dips and boiling, any ideas of advice would be appreciated? Thank you!
Gosh,how times have moved on.
Linklyfe or Castrol heated chain grease.
Sadly a long forgotten method, used before O ring chains or aerosol lubricants were invented.
Bet Y.G. has experience of this method. :thumbsup:
Posted: Thu Mar 28, 2013 9:34 pm
by desmarat
pinesol huh? I think i will stick with kerosene. Byt thanks for the reply, another idea indeed. Just looks like the kerosene way is the more commonly acceptable way to go about it. And i have never herd of heated chain greese, does it work better than regular spray wax? last any longer or give better lubrication or durability?
