Page 1 of 3
Starts, Runs, then looses all power???
Posted: Mon Feb 11, 2013 8:42 pm
by desmarat
So, i went to drive it tonight and got about half a mile from home and i lost all power, would not go past 3000 rpm's and when i tried it bogged like crazy. As soon as i got back and in neutral, same thing. i turned it off and the lights went out, key still in the off position. I turned it a few times and nothing, no power to anything. I let it sit for 10 min and tried again, success. Fired up and had full range of throttle. But im nervous to take it out and die on the side of the road, especially the highway. Any ideas, im lost!
Re: Starts, Runs, then looses all power???
Posted: Mon Feb 11, 2013 9:46 pm
by thatkid
Usually that means a crap battery. I've had it happen before where it starts and runs but as soon as the battery voltage starts to drop it starts to bog and won't go above 3k. Now it could be something else but I would check the battery first since it's easy.
Posted: Mon Feb 11, 2013 11:02 pm
by desmarat
thanks thatkid, motorcycle batteries are like car batteries in the fact that i should get 12 ish off and 13.5 or so running with gassing it a little right?
Posted: Mon Feb 11, 2013 11:45 pm
by desmarat
i have a motobatt battery in her now, MBTZ10U. 10 volt battery, it was what came with the bike. Is that sufficient or should i get a 12V battery in its place. I found a 12V mottobatt with these specs, are they okay to use on my FZR600?
MotoBatt SKU Ah CCA L x W x H (inches) L x W x H (mm)
MBTX12U 14 200 5.94 3.42 5.12 151 87 130 4 QuadFlex
Posted: Tue Feb 12, 2013 1:15 am
by thatkid
YB-12AL is the Yuasa battery for the FZR. I believe motobatt will cross reference, but yes you should have a 12v battery for the FZR. It's very picky about battery power.
Posted: Tue Feb 12, 2013 5:57 pm
The wasted-spark TCI ignition is very power-hungry; if the battery is getting low, then the starter won't leave enough for a decent spark.
I've been pondering a drop-in "dumb" CDI module, driven by the TCI signal, that would make the system far more robust and indifferent to battery state ...
Posted: Tue Feb 12, 2013 7:41 pm
by reelrazor
desmarat wrote:i have a motobatt battery in her now, MBTZ10U. 10 volt battery, it was what came with the bike. Is that sufficient or should i get a 12V battery in its place. I found a 12V mottobatt with these specs, are they okay to use on my FZR600?
The "10" in MBTZ10U is a reference to the battery's amperage rating-NOT it's voltage.
It's got six cells right? 1.5volts per cell makes it a 12V battery
Posted: Tue Feb 12, 2013 8:18 pm
Might wanna try this http://fzronline.com/wiki/doku.php?id=v ... flow_chart. Just to be on the safe side.
Posted: Tue Feb 12, 2013 9:43 pm
by desmarat
Okay, so I replaced the battery. Brand new 12v battery, did the same damn thing. I ran it down the block and all power took a shit. Came back for a minute and then went away again. Took it back home and turned it off with the key still in the on position, all lights turned off, everything was a loss. Would not turn back on for a few minutes, then turned on and turned over once then went off again. What the Hell!!!
Posted: Tue Feb 12, 2013 9:52 pm
by reelrazor
electrical problem
Posted: Tue Feb 12, 2013 9:59 pm
Yeah - loose, corroded or broken wire, switch, or terminal.
Posted: Wed Feb 13, 2013 1:28 am
by desmarat
ya, my issue now is where to start. The rear fearing was replaced im guessing by the previous owner. It has a R1 rear end, not installed right, and the electrical is botched. Shit was just hanging there, battery needed a box of cards in the battery box to hold it in place, fuzebox and starter solenoid were zip tied to the frame and the relays were the same. I bought the bike and put about 150 miles on her before anything happened and now im in a world of electrical hell. Anyone have any ideas where to start? I couldnt post any pics or i would let you guys take a peek. i tried photobucket ang linking a url but that didnt work either. If any one has any ideas please send them my way, i love the way the bike rides(when its running), and if i dont fix it soon my wife is going to kill me!!! :swear banghead :duh:
Posted: Wed Feb 13, 2013 6:19 am
by willandrip
Select the pic you wish to include in your post from your photobucket account.
At the right, in Image Links; copy the direct link.
In your forum post select Img from the boxes at the top of the page,
Two sets of brackets should appear in the text.
Paste pic. link exactly between the two sets of brackets.
Posted: Wed Feb 13, 2013 10:48 am
by desmarat
So, heres the bike. As soon as i get home ill take a pic of her insides.
Posted: Wed Feb 13, 2013 10:52 am
by willandrip
If at first you dont succeed;buy a parrot
