Page 1 of 2
FZR 600-elbows in mirrors-need replacement
Posted: Mon Jul 28, 2008 10:50 pm
by cyclestone
I just recently bought a 1990 FZR 600. When I am wearing my riding or my leather jacket (which is most of the time), all that I can see in the mirrors are my elbows. The mirrors are totally useless. Unless I lift my arm completely up in the air and take my hand off of the grip, I can't see anything behind me. And that is not always convenient or safe. I want to replace the mirrors with ones that stick out far enough to actually work all the time. Does anyone know of an aftermarket brand or ones from another year/model/brand of bike that will match up with the bolt holes on the FZR?
Thanks for your help,
cyclestone
Re: FZR 600-elbows in mirrors-need replacement
Posted: Mon Jul 28, 2008 11:06 pm
The quick way is to switch the mirrors. That will give you a little more visibility behind you. YZF600R (Not R6) Mirrors will bolt right up. They are bigger and make a big improvement over the stock "Mickey Mouse Ears". Mirrors from other bikes will fit in the stock mirror bases as well. For example I have GSXR mirrors bolted in the FZR bases shimmed with washers on my FZR.
Hope that helps.
Posted: Mon Jul 28, 2008 11:10 pm
by megaloxana
I went with these ebay cheapies two years ago and they're still holding together great. Visibility is great, no more elbows.
Posted: Tue Jul 29, 2008 12:49 am
by the_finch
I have really wide shoulders but found that the off-brand YZF600 black mirrors look good and do the job without breaking the bank. my2cents
Posted: Tue Jul 29, 2008 7:57 am
by zero9243
I just got these they look real slick
bolted right up
http://cgi.ebay.com/ebaymotors/_Motorcy ... .m14.l1318
Posted: Tue Jul 29, 2008 9:01 pm
by megaloxana
zero9243 wrote:I just got these they look real slick
bolted right up
Personally never thought they matched the fzr lines very well.
Posted: Wed Jul 30, 2008 3:45 am
by RCPlayland
I see ok with my mirrors. I mainly only worry about the cars I am passing. I can see, with a little leaning left or right, everything behind me.
Posted: Wed Jul 30, 2008 8:02 am
by ragedigital
I've seen other people, like sweek, put up mirrors that actually stick out enough to see around you.
Zero's might also be that way. The YZF mirrors are nice, but you still have to move your head to see around your elbows.
Posted: Wed Jul 30, 2008 9:28 am
by haunter
r1 mirrors let you see a ton but they look funny.....
and you have to drill a hole for them to mount up
Posted: Wed Jul 30, 2008 11:17 am
by zero9243
bolted right up
I have the airtech kit so maybe thats why i think they look good. The lines are a little diff.
Posted: Wed Jul 30, 2008 1:21 pm
by Baghr
Has anyone tried the ones that attach to the clip-on ends? Not sure what they would look like, but should be able to get around the elbows.......
Posted: Wed Jul 30, 2008 1:44 pm
by haunter
Baghr wrote:Has anyone tried the ones that attach to the clip-on ends? Not sure what they would look like, but should be able to get around the elbows.......
I'm workin on it eventually
Posted: Wed Jul 30, 2008 1:53 pm
I tried the bar end style as well. There's a lot of vibration going through those clips (hence the heavy bar end weights) and unless you fill them with bird shot and silicone you wouldn't be able to see out of them anyway.
Posted: Wed Jul 30, 2008 3:03 pm
by haunter
sweek what ones did you use?
Posted: Wed Jul 30, 2008 3:15 pm
haunter wrote:sweek what ones did you use?
Used this style but in black
http://cgi.ebay.com/ebaymotors/Parts-Ac ... .m14.l1318
