Runs like crap after a few minutes at high speed
Posted: Mon Oct 29, 2012 12:47 pm
So I normally am not too squidly, but last week I was coming home from work on the tollroad and found myself working my way to the front of the pack. Ended up running right around 100mph for a few minutes coming up a hill. After a couple of minutes it started losing power like I was running out of gas. I managed to run the speed limit by keeping the throttle wide open in 5th and took the next exit. I pulled into a gas station to fill the tank thinking that I had run out of fuel. It was low, but certainly not empty, but I topped it off anyway. Seemed to run OK on the way home.
My thought is that at that speed I either out stripped the fuel pump, or more likely had a problem in the float bowels. I have not adjusted the float levels since I rebuilt the carbs several years ago, but have not reason to think they are off all of a sudden. I also have had the vent tubes cause problems on some bikes and usually remove the tubes so that there is less resistance and it is easier for the pressure to equalize. This is a fairly common occurrence on older UJM's with vacuum actuated petcocks resulting in fuel starvation
Anyone have any FZR specific experiences like this that wants to offer other suggestions before I decide to dig into the carbs?
Thanks,
Mark
Thanks,
Mark
