recommend me some LED 1157 Tail light bulbs.
jax
Post by jax »
Getting annoyed with having to change out at least 1 bulb every couple of months. Is there a 1157 LED i can just drop in to the tail light? Don't care about the flasher side because i don't have turn signals on my bike and its not required in Texas. Any help would be appreciated.
Re: recommend me some LED 1157 Tail light bulbs.
If you're eating up tail bulbs, then either the mounting is off (too stiff = too much vibration; too soft = too much flailing) or your VRR is dying and your electricals are running too high a voltage. Measure the DC volts across the battery terminals at 5k rpm - you don't want to see more than 14.5vdc.
jax
Post by jax »
I know its too stiff since I have the R1 conversion tail light setup and the shock absorber rubbers are not there. Thats why I want to go with LED's.
GreyImport
Post by GreyImport »
I bought these for the 250 tail......but havnt tested them out as the bike is still in pieces :whistle
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 1009885000
1990 FZR250R 3LN1
http://2fiftycc.com/index.php
LiteTek Carburettor Seal Kits
HybridSport600
Post by HybridSport600 »
I agree with DonTZ125 your charg system is not acting right...and those bulbs are a big joke, made with cheap materials......check the charge at the batt with engine off, should be min of 12.0 to 12.5 vdc, then start it up and do the same check, should see between 13.5 to no more than 15.0 vdc, any higher and the system has a faulty VR, or bad stator, most likely the VRR
94 FZR 600 US- all OEM
