Genesis wrote:What will I need for the Oil cooler and bracket, what year YZF did you use, I have a 05 YZF radiator now.
Aside from the actual oil cooler and stud that holds it onto the bike, you'll need the yzf's coolant piping section that's over the stator cover, unless you put a T fitting somewhere inline with the rest of your system, the hose from the oil cooler to connect directly to this. I didn't try to put my FZR header back on after the oil cooler was in place, but it looked like it wouldn't fit, so I'm almost positive you'll need the header unless you can somehow find a short oil filter, and it would be a good idea to try to find the lower radiator bracket, it's two pieces, one small piece about 3 inches wide by 2 inches high, it bolts in above the oil cooler and the second bracket bolts to this and the radiator. The FZR oil filter base has to be removed completely to put the bracket on though. If I can find pictures of this stuff I'll post them up for you.
