Ohh, Yes, he did...660 the easy(?) way
Re: Ohh, Yes, he did...660 the easy(?) way
is it wrong I'm hoping for a bad winter to make me stop riding long enough to do this?
Collect enough data to give a jet comparison/break down? I ask as it will give the next person a little more of an inclination of what to expect AFTER putting the motor back together and in the frame. At least someone found a better way to do this. Good things all around.
660cc...13.2:1.....ported head..K&N drop in...kerker 4-2-1, pump 89
Using FP jet kit.
Have:
115 mains
35 pilots
FP needles, currently at highest setting (lowest slot)
Have very quick transitional flat spot from steady state cruise to accel..hiccups(lean flame out).....then takes off...
Will be raising fuel level, may necessitate needle drop after fuel level raised.
Otherwise, additional 70-80 miles ride in..still loving it. Gawd, some extra torque really really makes a difference.
Using FP jet kit.
Have:
115 mains
35 pilots
What about going to bigger mains? That could give you wiggle room with the needles. Just a thought though.
Are you running an airbox or pods? What carbs are you using?
Airbox.
Stock FZR carbs.
ohh, and 3 turns out (at this time) on the pilot screws
Stock FZR carbs.
- shredex
Sweet! I wanna see tons of pics with a write up on how to do it on the wiki XD
I had the yzf motor and everything ready for the 660 before my mess.
I'll be happy to see someone else doing it
I just finished installing mine today and actually started it up without drama. I'm looking forward to actually getting it rideable now.
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Meegacycle 276x3(* lift=.355" intake, .335" exhaust........duration=264°intake. 258° exhaust*) cams in.
Gawd it's strong.
(stock= .299" 238°intake, .288" 230°)
Gawd it's strong.
Had time to gather any dyno numbers? From the info you have given i would guess 110-115 at the shaft. i'm just guessing though
sweekster wrote:Had time to gather any dyno numbers? From the info you have given i would guess 110-115 at the shaft. i'm just guessing though
Nah, there isn't a bike dyno within 100 miles of me, besides the HD dealership which won't even book in a Jap bike..much less do a couple pulls then let me swap jetting in the parking lot.
There's a guy who trailers one around to the bike 'shows' around here. Those are usually pretty cheesy roller/inertial dynos and are probably fairly lax on calibration, etc.
But, he's kinda my only option. The next time that I KNOW he will be somewhere, I will get a few runs in.
hows this engine doing reelrazor im in the process of putting together a similar motor myself you using the fzr head and carbs sure i read somewhere you had ?
was gonna use the early fazer rods but typical there aint bugger all on fleabay at the mo so im going with the honed fzr rods
- HybridSport600
Im not as much worried about the rods holding, its more the old main bearing/Worn crank journals I would be worried about...All that time and thought, sounds great, but if you dont build the bottom, how do you expect the top to stay up?..........but anyways good luck
94 FZR 600 US- all OEM
Well, if I had seen ANY wear in any of the shells, or on any journals, I would have gone deeper, believe me.HybridSport600 wrote:Im not as much worried about the rods holding, its more the old main bearing/Worn crank journals I would be worried about...All that time and thought, sounds great, but if you dont build the bottom, how do you expect the top to stay up?..........but anyways good luck
What I saw/felt was not enough to warrant plastigauge, much less crank machining and/or shell replacement.
They guys here may remember my oil change rant from a couple years ago.....I'm a two to three thousand mile guy..plenty of oil, kept fresh, running through clean filters and the only time the rod and crank bearings will see ANY wear is on startup
- HybridSport600
Well good, But most damages that are detramental are the ones we cant see. but I hope all is well and verry powerful good luck man!
"four wheels moves the body, 2 wheels moves the soul"
