Cant get spark.
Re: Cant get spark.
Nothing wrong with those readings, especially the last pic. The coil is a transformer, and you're trying to measure resistance across two wires on different windings - I'd be concerned if you got any reading OTHER than 'OL'!
Re: Cant get spark.
Really? I was under the impression that there was a reading from the connector to the plug wire
Re: Cant get spark.
No - having 30-50kV backfeeding into a 12v system would be considered 'bad'.
Re: Cant get spark.
So the numbers are good. Cause I took that set off and replaced them with another set I found that ran the same numbers except on the plug wires. It was at 32.6
And if my coils are good than what could be wrong with the bike. I already replaced the control box and the relay. I have checked the wires for grounds, shorts, and breaks.
Only thing left is stator and pick up.
Re: Cant get spark.
I just tested the coils by using wire plugged into the harness and striking ends together and I WAS getting spark on all four plugs. so I plugged the harness back in and..... no spark.
so where do I go from here? My friend thinks it could be pulsar is bad.
