FZR To R6 Brake Swap Q's
- racerd14666
Re: FZR To R6 Brake Swap Q's
the easiest way to bleed brakes is to not fight gravity and reverse bleed them by filling the calipers slowly and let the air rise to the top with a syringe or a pressure bleeder and one squirt doing it the conventional way and your all done. but with only 12 miles on used pads and rotors there gonna take some time to break in you can speed the process up by sanding the pads flat or ride around with the brakes draggin
Yamaha Certified Technician
And try not to blue the discs as I know someone didracerd14666 wrote:the easiest way to bleed brakes is to not fight gravity and reverse bleed them by filling the calipers slowly and let the air rise to the top with a syringe or a pressure bleeder and one squirt doing it the conventional way and your all done. but with only 12 miles on used pads and rotors there gonna take some time to break in you can speed the process up by sanding the pads flat or ride around with the brakes draggin
my uncle is a policeman. He says that your "ride around with the brakes draggin" is highly dangerous and illegal. is he rightracerd14666 wrote: ride around with the brakes draggin
Personally, I'd find a nice quiet parking lot and do some hard braking passes. Dragging the brakes while riding is asking to have your fronts lock on you.
Would get some new pads myself and save the bother they don't cost much and if you get sintered pads, well let's just say I am pretty impressed how good they r
FZR600R '94'
Bluespot calipers
Wavey front discs
R6 front mastercylnder
Mild steel chain adjusters
Art can with removable baffle
Carbon fiber chain guard
Glass fiber rear seat-hump
Bluespot calipers
Wavey front discs
Thats what my uncle told me to do so i am. He is a police motorcyclist, he was very mad when I was considering riding around with the breaks dragging. He told me that my break light would be on all the time, other road users would have no idea when I was actually trying to stop, they could more than likely drive over me and well.... kill me. Then he gave me a lecture.dougs wrote:Would get some new pads myself and save the bother they don't cost much and if you get sintered pads, well let's just say I am pretty impressed how good they r
All bike riders should at all times consider every other road user to be a idiot, your vulnerable at all times, if your an idiot then you will get injured and possibly killed. He is really concerned that a "Yamaha Certified Technician" is advising that people should ride around with there breaks dragging (break light on) blah blah
He has a point but then again I have done it and in some very rural back roads and using my mirrors to see if any thing came up behind me (i.e. the bit he did not mention or you failed to quote "rider awareness") then use sense and come off the brakes.
I might add that most brake lights pressure or spring actuated do not come on immediately any thing is applied to the lever there is ALWAYS some play in the system or else the lights would come on at the slightest bump.
Hmm.....yamaha_george wrote:He has a point but then again I have done it and in some very rural back roads and using my mirrors to see if any thing came up behind me (i.e. the bit he did not mention or you failed to quote "rider awareness") then use sense and come off the brakes.
my uncle says that well... the guy is wrong (I can't print what he actually said, it's abusive) we are talking about the front break, there's no way (say's my uncle) that the front break light switch would come on unless the front break is applied!
First, it's "brakes" - sorry, pet peeve.
Second, if you are dragging the brakes enough to skim the pads, you ARE activating the brake light.
Third, there is only ONE brake light (cluster), activated by either switch. There is no front brake light / rear brake light.
[quote="DonTZ125"]First, it's "brakes" - sorry, pet peeve. Thanks
Second, if you are dragging the brakes enough to skim the pads, you ARE activating the brake light. <<<<Very dangerous
Third, there is only ONE brake light (cluster), activated by either switch. There is no front brake light / rear brake light. what there's no rear brake light???? you are wrong[
I meant the front brake light switch, which will activate the REAR brake light!!!!!! thanks for your useless input!! Ive bought new pads, I will install them.
"There is no front brake light / rear brake light" I beg to differ. There is rear brake light
There is no separate front brake light vice rear brake light. Get over yourself.
Congratulations on the fresh pads; that probably is the best solution.
there is a front break switch and a rear break switch, both activate the rear break light!!!DonTZ125 wrote:There is no separate front brake light vice rear brake light. Get over yourself.
Live with it
I suggest that this thread terminates as of now, a solution is found and further dialogue is pointless, both of you have made your points the reader can make up their own minds as to the validity of the argument put forward.CJD wrote:there is a front break switch and a rear break switch, both activate the rear break light!!!DonTZ125 wrote:There is no separate front brake light vice rear brake light. Get over yourself.
Live with it
What happened to my thread? Haha thanks for the input guys i ordered new pads and found some rotors at my local junk yard (:
But my brakes seem to be much better now a few days later.
