Header came loose...
delvryboy
Level 5.0
Level 5.0
Re: Header came loose...
Post by delvryboy »
So, like copper terminals that have 2 bolt holes?
'92 FZR600
Lots of Powder
delvryboy wrote:So, like copper terminals that have 2 bolt holes?
Yeh sort of you do not want copper ones but steel ones (copper will not last 10 mins as the springs will vibration cut thro them )
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
I'm going to pick up the springs tomorrow. Should I use something like throttle return springs, or something heavier?
'92 FZR600
Lots of Powder
Post by thatkid »
Finally got them. They should look like this. And they should be heavy duty. To get them off takes a serious grip on some pliers or vice grips locked on and pulling hard. Too weak and they won't hold the pipe on.
thatkid wrote:Finally got them. They should look like this. And they should be heavy duty. To get them off takes a serious grip on some pliers or vice grips locked on and pulling hard. Too weak and they won't hold the pipe on.
TK,
I notice your spring end just goes over the flange. Do the flanges have alip to hold the end of the spring or a hole ?
Just curious as all the race systems i have used / seen had the tab washers I talked about .
Post by thatkid »
There is a hole that the spring goes through.
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
I'm about to head out now, I'll check for holes in the flanges.
'92 FZR600
Lots of Powder
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
No holes. I got some springs, I just have to figure out how to hook them up top. I'm thinking over-sized washers and slide them to one side.
'92 FZR600
Lots of Powder
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
Any thoughts on using an exhaust epoxy for the pipe>coupler? The flange would still float free.
'92 FZR600
Lots of Powder
delvryboy wrote:No holes. I got some springs, I just have to figure out how to hook them up top. I'm thinking over-sized washers and slide them to one side.
That or drill the hole in the flanges ????????????
reelrazor
Wrench
Wrench
Post by reelrazor »
If you know you have springs that will make it, you can bend a right angle sideways (vise and hammer) to the 'hook' end of the spring and then trap that under a bolt head (use IT as a washer-put a normal flat washer on top of the hook.
From this:
To this:
I--------------///////////------------->
sweekster
Post by sweekster »
I was thinking the same thing
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
I'm sure there is some good reason to use springs, however, I welded the couplers to the pipes. I wasn't happy with how I had the springs on nor the springs I found as well.
'92 FZR600
Lots of Powder
delvryboy wrote:I'm sure there is some good reason to use springs, however, I welded the couplers to the pipes. I wasn't happy with how I had the springs on nor the springs I found as well.
D,
I hope you welded (tacked at least ) while they were on the bike or they will not automatically line up ( Do not ask how I know this ) If you arc welded I hope you disconnected the battery & the TDI as they have a habit of going KIA on you shortly afterwards.
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
I tacked them off the bike. Everything lined up pretty good. :thank goodness: I thought about that after the fact. It was a real pain to get the pipes all the way up to the inner lip in the coupler, I doubt I would of been able to do it with the couplers already bolted to the head. I used a liquid exhaust manifold weld inside the coupler and then put a couple tacks per pipe. The couplers are a softer aluminum and I didn't want to burn them up.
I know though, it would of been a disaster had everything not lined up.
On another note, these pipes haven't been all the way in for a long time. It took me 30 minutes to get all of the carbon cleaned out from the inside of the couplers.
'92 FZR600
Lots of Powder
