Here is the fork tool I made when I did the seals on my old 600. I'm sure someone else will chime with their version of it or doing a search might yield something else.match417 wrote: ****as far as the forks go..that custom tool that I have to make, is the nut on the end of the all thread really 5/8 (16mm), that's a bit large to be on the inside of the fork tube. Something up with the wiki-thread about replacing the fork seals, I remember it mentioning the nut on the end of the thread being 5/8, is that the head of the nut? I went to double check and couldn't read the wiki.
it's a 3ft x 5.8th threaded rod and 6 nuts. Two nuts locked at the bottom (this end goes inside the fork to hold the damper rod in place) and 4 nuts locked together higher up the rod to act as a handle. The PVC tube in the pic is used as the seal driver.
