What's your MPG ?
Re: What's your MPG ?
My FZR needs a good carb go through/rebuild (among other things ) but it still between 35 and 40 MPG and currently has 36K miles on it. My Kawi gets 45 to 50 mpg consistently and currently has 3500 miles on it.
I get around 40 - 50 MPG , SHELL and EXXON fuel .... 22000 miles ... 98 FZR , i have plans to gear up , don't like 6 grand revs trying to keep up with interstate traffic ... too much wear & tear for me ... i'm gonna ride my FZR to the end of the world .. .. yeah
- Level 8.0
IT's a said day for me... 399 for regular at the cheapest stations.. most others are over $4 now.. The good news! I'm driving my bikes more than ever!! I take a bike to work at least 2 days a week to cut down on gas.
NO FZR
05 Yamaha R1
03 Harley Fatboy
what's next?
05 Yamaha R1
03 Harley Fatboy
what's next?
- joeyraines
Im getting about 60 mpg if i cruise, and about 55mpg when im really ridin. Im 6'0, 140 dressed. Just rolled over to 14K.
got 39.5 on friday on the 1040
got 30 today
almost had a long walk cuz of that, thank for reserve!
There was a very stiff headwind today
got 30 today
SOLD
SOLD
I have a mostly stock bike that I am getting 48-50 mpg. Back when I had the 16t front sprocket, I was getting as good as 55mpg.
- William Burroughs
- Karl Marx
- William Burroughs
- Karl Marx
k&n filter, hacked airbox, yoshi slip-on, lower gearing, shimmed stock needle(was and still lean i think). 35 mpg. 15k. 5'10" 187#. different octanes and don't really see a difference. Must be some way to get the MPG up. I know I need a jet kit.
If you don't have the money, YOU CAN'T AFFORD IT!
93 FZR 600
YZF Tank, 02 R6 subframe and tail, Airtech R1 kit w/stock 5" headlight,
R6 VR, Flush mount front signals, License plate rear signals, R6 battery
Painted myself, Yoshi Slip-On, Chrome Wheels, 520 Chain and Sprocket
Conversion, R6 Nissin Front Master Cylinder, Racetech Springs
93 FZR 600
shooshine_jonnie wrote:k&n filter, hacked airbox, yoshi slip-on, lower gearing, shimmed stock needle(was and still lean i think). 35 mpg. 15k. 5'10" 187#. different octanes and don't really see a difference. Must be some way to get the MPG up. I know I need a jet kit.
replace your emulsion tubes. crappy running AND crappy mileage usually mean sthe tubes are oval'd
SOLD
SOLD
30-35 dammit. Replacing plugs today to see if that helps
Upgrades:
I checked the emulsion tubes and they look perfectly round to me. Trust me I tried to make them look ovaled cause I want the problem to end. Do you think I should change them anyway?haunter wrote:shooshine_jonnie wrote:k&n filter, hacked airbox, yoshi slip-on, lower gearing, shimmed stock needle(was and still lean i think). 35 mpg. 15k. 5'10" 187#. different octanes and don't really see a difference. Must be some way to get the MPG up. I know I need a jet kit.
93 FZR 600
93 FZR 600
I dunno
I think those dont look terrible, and imagine how hard that is to spot without it being blown up...
There is a way to check visually thats easier I was told but I dont remember what you have to do exactly
but when you open the throttle while looking down the carbs instead of coming out in a good spray you get blig globs of fuel spiting all over from the ovaling
Hijack! If I have the airbox off I can see the gas going in when I crack it open. Should this be a mist cause I have more of a non fine spritz?
93 FZR 600
93 FZR 600
unsure.shooshine_jonnie wrote: Hijack! If I have the airbox off I can see the gas going in when I crack it open. Should this be a mist cause I have more of a non fine spritz?
Thats what I was led to believe but I dunno if its true
SOLD
SOLD
White Lining??95FZR600 wrote:Thats it! Damn, your not saving much money. You must sit in a lot of traffic. Try white lining!zero9243 wrote:30-35 dammit. Replacing plugs today to see if that helps
I put new plugs in and it didn't change anything. I am going to try a tank of regular gas instead of premium and see what happens.
Upgrades:
In my observation, regular 87 seems to make my FZR much happier than 93. Other people here will say the exact opposite. Who's right?zero9243 wrote:I put new plugs in and it didn't change anything. I am going to try a tank of regular gas instead of premium and see what happens.
