Hi,yamarossi46 wrote:Hello. I´ve used nylon caps.
did you use solid nylon or tube ?
If tube i doubt it changed the air mass above the spring much,a lot of guys do not realise that the air gap above the spring is MAJOR factor in the action of their forks ( as suspension) acting as an air spring !
