Electrical Issues and More
Re: Electrical Issues and More
It turned out that the starter clutch was messed up so it busted the gear. A new yzf starter clutch and gear solved the starting problem.
Now I have a starting issue. I can run the bike until the battery is dead. I have two questions, my buddy had a buel and said his bike didn't charge until he was running over so many rpm. I left my volt meter at one of my job sites and I haven't been back in over two weeks so I can't exactly check the ohms or anything on the stator. But I did have a busted wire going to the little thing-a-ma-jig that I re spliced and added a silicone dolphin and I redid the connections to the wiring harness with new weatherproof quick disconnectors.
At what rpm does the stator charge the system or is it always charging?
Will a yzf stator fit on a fzr?
Here are the stators I am thinking about buying
http://www.ebay.com/itm/Yamaha-1989-199 ... 4897.l4275
http://www.ebay.com/itm/NEW-YAMAHA-YZF6 ... 4897.l4275
http://racetechelectric.com/i-8156024-y ... tator.html
A YZF stator will fit the FZR *but* the crank pickup wires are reversed. You'll need to swap the two wires, or you'll never get spark.
It's more likely that your VRR is fried than your stator; have you followed the Voltage Regulator Troubleshooting Chart?
Kind of. The first thing I did to the bike was buy the new and improved voltage regulator, cut the old connections and make new ones.
Hmmm ... Three white wires to white wires, red to red, black on a dedicated 12ga wire back to the cylinder block?
Not exactly, I just wired it into the wiring harness. Whites to whites, red to red/white I think and black to white/black I think. I was pretty sure wires were matching, almost like it was the original stator. Some dumbass wired in a trailer connector to replace the factor connection.
Is it worth grounding it specifically to the engine block, both the stator and the voltage regulator?
WOW. Red/White is the switched/fused +12v downstream of the ignition switch; that could be why your battery is draining overnight. White/Black ... that's one of the crank pickup wires??
Can you put up a pic, or email a pic of your VRR connector and wiring?
The stator should NOT be grounded. There are 3 wires from 3 windings in delta arrangement, putting out AC. Connecting that to the ground side of your DC electrical system will do bad things to just about everything.
the black wire is connected to one of the bolts connecting the VR to the frame.
Maybe it is a white wire with a red line and a white wire with a black line and three white wires coming off of the stator.
Ahhhh, nuts.
You've fried your VRR. The OEM 4-pin regulator grounds through the body. The later 5- and 6-pin VRRs have an actual ground pin (top right as you look at the pins) that must be connected to ground - preferably the engine block or the battery -ve terminal.
No way... So because it wasn't grounded through the pin it has been fried?
Yup. A bad ground is the fastest way to kill a shunt VRR, and it looks like yours didn't have ANY ground.
Well that really sucks. I only have about three hours on the bike idling and revving it to try and set air/fuel. Is there any sort of hope that it's not toast? Would the only symptom be that it is not charging?
Oh, the rest of it's fine - I'm trying to picture how UNDER-charging would screw anything up. So long as the battery was reasonably charged when you were doing your tuning, nothing much would change.
Yeah the rest of the bike is running. Since I corrected the grounding issue it has been running for about twenty minutes no issues. The head lights are brighter when it is running versus just being on.
Bring it up to 5k rpm, and check the voltage across the battery terminals - you might have gotten lucky!
She lives!!!
I was able to take her out on Saturday and able to ride around for over an hour and a half. She is still not exactly acting right.
The biggest issue is the front brakes. they are still not as firm as they need to be. just going about 25 in a parking lot i wasn't able to stop as quick as i should. I think the rear brake has more stopping power then the front. I am hoping zip tieing the front brake lever open will help get a nice firm lever. Otherwise i will probably just order a complete set, master cylinder, brake lines and calipers already connected. Maybe it is just the master cylinder but it wouldn't hurt to have a spare set of calipers.
I still think a carb syncing is in order. I was able to get rid of the backfire with adjusting the air/fuel screws. I am still thinking something is out a whack with the carbs. A shop wants about $80 to sync the carbs and adjust air/fuel ratio but i can order a sync tool for the same money. Does anyone think it is worth taking it into the shop?
Thanks for all the input so far.
