willandrip wrote:Did it operate the starter when you jumped the solenoid ?Sugoi wrote:Anyone here happen to have a spare solenoid they'd like to sell?
No. I just get a faint "click" from the solenoid.
Ya true.willandrip wrote:Well you need to know 100% the solenoid is faulty before you go replacing it,that is why the test is important.
To replace electrical items without testing is a very expensive option.
It is to save removing the tank to gain access to the starter motor itself to do the next test!
Sounds good. Let me know.Sugoi wrote:Will do Brandon!
Hopefully today I'll be able to pull the cover off and check the gears. If they're alright, maybe Sunday or Monday I'll shoot up your way to try a solenoid out.
I think he was referring to just testing the voltage. Initially, I don't think he load-tested it. As most of us already know, the battery can have what appears to be good voltage yet have zero cranking power. I believe this will prove to be the case for him. Let's hope so anyway.willandrip wrote:Lesson of the story....Check your battery if it doesn't start, regardless of the PO words.
At the start of this topic you did state that you had tested the battery;
" I tested it at work and it had 14v (I believe) while sitting, and about the same at idle."
