hello guys bike is doing well main frame is being powder at the moment cant wait to have jer back !!!
but anyways im after changing my forks to better ones adjustable ones any ideas what I could use already have a adjustable shock so thought i do the forks aswell
91 fork upgrade?
Re: 91 fork upgrade?
The YZF600 Thundercat had fully adjustable forks. I don't believe the legs fit in the FZR clamps, but the whole assembly will bolt right up.
thanks buddy will look into a set of thundercats
when you say the whole assembly ie forks clamps bars... will I need additional spacers maked for the front wheel or is the diameter same also the calipers still in same space?
thanks buddy
thanks buddy
You need the entire YZF front end. 96+ I believe for the better forks. Might be 97+ it will bolt right up though.
Do YOU Scopper?
cool even the headlight cowl unit ? so many questions haha
thanks again
thanks again
Nope that part can stay. Just the whole fork/wheel setup.
Do YOU Scopper?
coool thanks buddy
I just installed an entire front end from an 08 r1 on my 92 fzr660
Contrary to popular belief, nobody owes you anything!!!
