I think I get whet your trying to say,
That sux, I know how frustrating this can be. I coulden't really tell if you said the plug had stripped out, or the cyl head.
If it was the cyl head, it needs to be removed, pending on how bad it is itmight need replacing, or you can always take it to a welding shop and have them TIG weld a nice consistent bead on both the inside and outside of the plug hole. then some one will have to drill it back out to a smooth bore hole. Then use a plug thread tap to reset the threads.......(Wheww!! breath..).....If it is the plug that has pullued threads, its possible to use some tweezers and pinch the top most piece of the thread, and wiggle it out side to side in a "reverse turn" motion, but be careful not to drop any small pieces down inside as this will be verry bad. If this method is used, I suggest the use of a magnifying glass preferably a lighted one with a large 4" or bigger glass. If you do drop a piece into the cyl, there is no choice but to pull the head,its possible you could vacume the piece out, but I would not take the chance. if it was just the plug, once you clean it out take a "Plug reamer" and oil it up and run it in and out of the threads a few times. hope this helps you out, good luck mate!
Let me know if I can help you any further
"Got a $5 dollar head, get a $5 dollar helmet"
